Useage ?
kevinneilldsl
Useage ?
Hello just a question might sound stupid but if i go Over my 60 gb allowance Will that affect my Speed in anyway? if not whats the affects?
thanks
Fixes: 8
Re: Useage ?
It depends on what you have set on this page: https://portal.plus.net/data_transfer_watch/
If your extra monthly spend is not set you will be automatically charged £5 for each 5GB or part thereof you use.
If your extra spend is set at zero your speeds will be severely restricted (including overnight) until your next billing day.
If you have an extra spend set you will automatically billed up to your set limit. If you then go over your speeds will be restricted.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
kevinneilldsl
Re: Useage ?
Ok i should be ok i've used 34.36GB of my 60GB allowance
Fixes: 8
Re: Useage ?
If you haven't set it I suggest you set the watch to zero to avoid surprises. We've been trying for months to persuade Plusnet to make that the default.
kevinneilldsl
Re: Useage ?
Hey jelv how do i set the watch to zero?
Re: Useage ?
Use the link that jelv provided in reply#1 ( https://portal.plus.net/data_transfer_watch/ ) - you'll need to log in to the member centre - then enter 0.00 as your 'maximum extra monthly  spend'
Call me 'w23'
kevinneilldsl
Re: Useage ?
Done! Thanks for Help jelv & walker Smiley
