Usage
Mitten
Usage
I play a lot of games on my iPad and didn't think I used the web that much.
Apparently I have almost used my monthly allowance.
Am I using a lot because the games link to the web?
Not very bright when it comes to usage etc. Crazyl
1 REPLY
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Usage
Hi Mitten,
It looks as though there has been a bit of streaming as well which can soon add up. If you use more than 10GB per month, it might be worth taking a look at our <a href="https://www.plus.net/home-broadband/unlimited/> Unlimited Product?</a>
If you decide you'd like to change packages, you can do that <a href="https://portal.plus.net/apps/account/change/4866895/CurrentAccount">here</a> (Login required).
Chris Pettitt
Cloud Environments Engineer
