Usage
jorvikmik
Usage
If you stream a webcam from your own home server on demand what category should it register under for usage?
Just wondering as I get about 6% usage for gaming but don't use gaming. Just webcam on demand with 60 second timeout & max of 3 users plus upload about 100kb of data per minute 24/7
I am still keeping under my usage limit so no worries at the moment , just curious.
1 REPLY
Fixes: 68
Re: Usage
That depends on how the traffic is identified, part of that depends on what ports are being utilised for the stream. If you can find that out for me that may help us identify that for you.
Adam
 Adam Walker
