Usage Breakdown
- Usage Breakdown
Usage Breakdown
25-11-2012 4:30 PM
What is the purpose/reason for a list of a users broadband breakdown into a list such as Web,e-mail,Gaming,streaming etc ?
Everyone will have an allowance on what they use so if the total used can be displayed at any time why is it broken down further ? and how accurate is it ? for example I have sent and received a number of e-mails this month but looking at the breakdown list nothing is showing ?
None of this is a problem just curious
We are born into history and history is born into us.
2 REPLIES 2
Re: Usage Breakdown
25-11-2012 5:15 PM
Well, it can give you an indication of whether your traffic is being correctly identified (& prioritised), without the use of a wireshark capture. Especially useful when you can't run wireshark on a device.
Also helpful for people to change their usage patterns if they regularly reach their monthly allowance.
That's RPM to you!!
Re: Usage Breakdown
25-11-2012 5:25 PM
Or a rough and ready idea if your WiFi is being hacked when you see excessive traffic on a category you don't normally use much.
