Urgent plse help
- Re: Urgent plse help
Urgent plse help
27-10-2016 2:19 PM
All, just about to go live with ADSL and have a hub zero (sagem 2704n). As I have my own router, I would like to use the plusnet router in modem mode. Is this possible and how? I have been searching the net and this forum for a few hours but not got any answers. Please note its HUB Zero. Thanks
27-10-2016 2:31 PM
Not for the faint hearted, but this thread might be useful https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Unlocking-the-potential-of-Sagemcom-27...
Appears you SHOULD be able to do it by editing the config file.
27-10-2016 2:38 PM
What router do you have? It might be easier to use that on its own?
27-10-2016 4:06 PM
Thanks for the link MisterW, far too complictaed for me and risky. As for the router I have, its TP Link WDR4300, its wifi strength is excellent and is dual band but does not support ADSL. I currently have Sky ADSL and using their router in modem mode.
27-10-2016 5:34 PM
Ok, well unless it's possible to use the Sky modem with another ISP ( which I doubt ) then best thing might be to go and buy a modem. I've just bought one of these http://www.argos.co.uk/product/5728882 to use as a modem for my Fibre upgrade. It supports ADSL & VDSL so you would be future proofed if you moved to fibre. It is a fully fledged modem router but does support 'bridged' mode i.e modem only. As you can imagine, for the price, it lacks some facilities as a router, no wireless AC , no GBe but by all accounts it has a good modem. I haven't tested it in ADSL mode yet, but it worked fine on my office VDSL line. I will be putting it on my current ADSL line at the weekend in prep for the fibre changeover next week
31-10-2016 7:27 PM
01-11-2016 11:27 AM
Its an SR102
https://www.youtube.com/watch?v=id7mLqemtfc&feature=youtu.be
Connect both routers using Lan ports and used the same setup for hub zero too. Not perfect but it does work.
01-11-2016 11:44 AM
Ahh that explains it, you're not really using the Sky router in modem mode. It's still a modem/router , you're using the 2nd router just as a wireless access point.
