Upstream Usage Question
- Upstream Usage Question
07-03-2012 4:49 PM
Hi, I'm a new customer and I have a question about the usage policy, I've looked around for info on this subject but there doesn't seem to be any mention of it.
Basically, My new connection is for a online radio station, Which will be upstreaming to ustream. My question is, Is the upstream classed as a download? I have a 60GB p/m usage limit,
And as I plan to be online 24hrs a day, It is important that this does not result in £5 per 5GB charges to my account. Can someone please verify this? Thanks!
8 REPLIES 8
Re: Upstream Usage Question
07-03-2012 4:55 PM
Quote My question is, Is the upstream classed as a download?
It's classed as an upload and will count towards your monthly allowance, yes. You can keep track of your usage here: https://www.plus.net/view_my_broadband_usage/index.php
07-03-2012 8:56 PM
Hi djdat
Go to the members centre and ensure that you're monthly spend (as in extra spend) is set to £0.00 (to ensure you dont get overbilled) - however if you go over your 60GB/month, you'll be rate limited.
Streaming doesnt require that much bandwidth though, even if you were doing it 24/7
(but obviously, the higher bitrate you use the more bandwidth you'll burn)
Regards
Regards
07-03-2012 9:00 PM
07-03-2012 9:01 PM
Which providing you're not doing anything else on the line - it should be enough for a reasonably high quality stream
Regards
Regards
09-03-2012 7:06 PM
Thanks guys. I was using a talk talk line before and the upstream was 50-80kbps, Which was suitable enough for my needs. I won't be doing anything other than the occasional windows update on the machine itself, So I should be ok.
I will set the limiting thing just in case and keep an eye on the usage during my first month. When the station is up and running I will post up the link for you guys to come listen! Thanks again!
12-03-2012 12:04 PM
Glad to hear you got it sorted, doubt upload will cause you any issues but please let us know if there are any. Look forward to checking out the show!
24-03-2012 12:47 AM
The site is up now and here it is!
Progressive House, Tech House, Deep, Minimal & Techno - Come check us out
www.sdancelive.com
01-04-2012 9:11 PM
Hi DJDat
Have added your station to my home music streamer, sounding good!
James
James
