Uploads to IONOS
Uploads to IONOS
No really a Plusnet problem but I thought I would pick peoples brains here's as IONOS support can be difficult needing you to phone them . I host six amateur related websites on IONOS. They are not very big sites but require multiple uploads of small amounts of data very frequently - realtime.txt for example is updated from each site every minute but is very small in size. All are uploaded via SFTP. All have been working smoothly for years.Recently I have been getting "connection refused" error in the logs. The uploads are normally tried a few times and then goes ahead mostly or sometimes fail till the next upload cycle. Nothing has changed has far as I can see. Any ideas?? (Another than ring IONOS and wait on the line for  "while")
1 REPLY 1
Fixes: 479
Re: Uploads to IONOS
Moderator’s Note
This topic has been moved from Full Fibre to Tech Help.
