Upload Speed
dacloudster
Upload Speed
Hi, Plusnet Staff and, I want to know if i can get my upload speed incresed, are some way to get a better upload speed i know you dont relly get much upload speed.
In the first place but i like makieing videos for my Yputube channel and uploading them, But the speeds are very poor it takes like 40mins jst to upload a vodeio that not even HD jst round about 65Mp are somthing,
Of course HD would take for ever no doupt  Cheesy
And yes before i get asked "try turing other programs or connection that use bandwich" Done it.
Edit:Oh By the way almost forgot to mention i also use a  ethernet conetion not wireless.
Infinity
Re: Upload Speed
Do this & come back with results
http://www.speedtest.net/
or this
http://www.mybroadbandspeed.co.uk/
Do either ( or both ) test at least twice in quick succession.
And ..... keep an eye on your usage, a good search of the forum will give you a lot more info on this.
dacloudster
Re: Upload Speed
The Cabinet  is  lke 3 mins away from were i am..
And whats Splchk
And CBB
And my usage is fine may have gone over but dont matter, Im fine with the extra chagre
Infinity
Re: Upload Speed
Your speeds are not bad at all, certainly better than a lot of users.
I am quite happy with my upload speed,  to me, download speed is what matters for my needs.
You can ask to be uncapped, which may double your upload speed.
Usage: You may also wish to upgrade to 60mb per billing period, for £5, if you are only on 10mb per billing period.
Re: Upload Speed
Hi dacloudster,
I've placed an order to uncap your upstream for you, should be done tomorrow Smiley
dacloudster
Re: Upload Speed
@PlusComUK lol thats what i did the other day upgraded to Extra, Wount be active till after my first billing date, Smiley
@Matt Taylor thank you Smiley
