Upgraded to Ubuntu 9.10, touchpad & sound problems
- Re: Upgraded to Ubuntu 9.10, touchpad & sound prob...
23-04-2010 6:18 PM
Today in my wisdom I decided to upgrade to 9.10.
It seems to have upgraded but now there is no sound, the touchpad is not working and the whole thing is sluggish
I would appreciate some advice on how to fix this please.
Re: Upgraded to Ubuntu 9.10, touchpad & sound problems
23-04-2010 6:44 PM
23-04-2010 6:48 PM
The laptop is an Acer 5610Z dual booting with XP
23-04-2010 7:22 PM
Touchpad is another can of fish!. Search in Synaptic for touchpad and see if there is a new driver there.
23-04-2010 7:33 PM
23-04-2010 7:34 PM
Quote I had a very nice & nifty 9.04 set up dual booting on my laptop. It wasn't broke so I should have left it alone
Sorry to hear that Santiago.
Have you tried a 10.04 Live CD, I think the RC is out now. If that works ok then it may be worth upgrading to that. The release is due for 29th of this month. I must admit I experimented with 9.10 ( my netbook is still running 9.04 ) but it broke my 3g dongle so I decided I would wait for 10.04.
In preparation I did split my /home to a separate partition so that a 10.04 install would be possible later.
I've been testing the 10.04 Beta using VirtualBox on my desktop and its looking pretty good to me.
23-04-2010 7:36 PM
23-04-2010 7:47 PM
Quote 1.Add user to audio group
sudo adduser 'you' audio
2. Delete contents of ~/.pulse
3. Reboot.
Have you already found and tried that Santiago ?
23-04-2010 8:17 PM
However I was just fiddling about with the drivers in Synaptic and re-installed the touchpad drivers. When I rebooted I got a pop up asking me if I wanted to keep the existing menu.lst.
Now during the upgrade I had selected "keep existing menu.lst" but this time I selected.........err the one at the top.
When it was rebooted the Touchpad and the sound were working. I am now going to have a good look around and make sure everything else is working.
Regarding 10.04, I normally wait a while until the new versions have had a good shake down before upgrading, hence my efforts today with 9.10!
Edit: BTW Opera has disappeared!
24-04-2010 3:04 AM
Does the boot entry stuff near the end of menu.lst correspond with your updated kernel?
24-04-2010 7:15 AM
Quote Regarding 10.04, I normally wait a while until the new versions have had a good shake down before upgrading, hence my efforts today with 9.10!
Yes I would tend to agree with you there. I do get the impression that since 10.04 is a LTS release its not quite as cutting edge as 9.10 and from my tests with Virtualbox its looking good.
24-04-2010 9:03 AM
Quote from: A Does the boot entry stuff near the end of menu.lst correspond with your updated kernel?
It does now.
