Updating website - originally Madasafish & Freenetname
dougle25
I have been updating my website using terrapin  software and have been publishing to it without a problem for a few years.
My old PC broke and having got a new one I haven't been able to get the correct settings needed to continue to publish.
I cant seen to get the right FTP server address ?
The only information I have found is from an old madasafish webpage and this doesn't work!
Many thanks in advance.
5 REPLIES 5
bobpullen
Fixes: 330
Re: Updating website - originally Madasafish & Freenetname
The server address should be www.users.freenetname.co.uk as far as I recall, however that is currently returning some odd DNS results for me Huh
~$ host www.users.freenetname.co.uk
www.users.freenetname.co.uk has address 0.0.0.0
www.users.freenetname.co.uk has IPv6 address ::
Try using ftp.freenetname.co.uk instead and see if that's any better.
dougle25
Thanks for your help.
But the addresses do not work
bobpullen
Fixes: 330
Define 'do not work'? What actually happens when you try connecting?
The second address looks fine from here: -
~$ ftp ftp.freenetname.co.uk
Connected to ftp.freenetname.co.uk.
220 ProFTPD Server [freenetname.co.uk]
dougle25
Thank you very very much it works , you have made me very very happy
Thanks Again
Dave
bobpullen
Fixes: 330
No worries Dave, glad I could help.
The other address should work aswell to be honest, so I'll see if I can do some digging as to why it isn't.
