Updating from XP SP1
- Updating from XP SP1
19-02-2012 5:40 PM
Microsoft isnt letting me upgrade an old PC from XP SP1
It appears that all their support for it has been witdrawn
Does anyone know of a site where I can download the necessary updates to CD?
2 REPLIES 2
Re: Updating from XP SP1
19-02-2012 5:42 PM
If Windows Update won't do it this
http://www.microsoft.com/download/en/details.aspx?id=24
Will take you up to SP3
22-02-2012 6:10 PM
Thanks for that
Problem solved
Your a star
adie:quote
Problem solved
Your a star
adie:quote
