Update Driver Software?
joecool
Hi I've been getting the BSOD seemingly caused by 'ntkrnlpa.exe could anyone recommend any driver software? There seems to be a lot out there that misinforms you of which drivers actually need updating! just so that you purchase their product.
My OS is Vista & all updates are installed. Is there any free software out there?
Thx
ckcomputing
Re: Update Driver Software?
Hi Joecool,
You could download Secunia's Personal Software Inspector (PSI) This is free and will alert you to any software/driver updates needed.
http://secunia.com/vulnerability_scanning/online/
Professionals are predictable - it's the amateurs that are dangerous!
joecool
OK Thx will check
Fixes: 10
Isn't ntkrnlpa the kernel? Not sure if a driver update is going to help. If you've recently done any updates I suggest a roll-back might be a more appropriate first step.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
joecool
Yes............NT Kernel & System            thx
