Unrequested changes to Internet Explorer
- Unrequested changes to Internet Explorer
- « Previous
- 1
- 2
- Next »
Re: Unrequested changes to Internet Explorer
13-05-2014 5:08 PM
It could muck up your dual boot
13-05-2014 9:58 PM
14-05-2014 6:37 PM
I'm not sure what to do now. If in a couple of hours I am still waiting for Windows to set up the video, I will stop again, and try to install Windows 7.
Its just as well I am being philosophical at the moment. If anyone has any suggestions, please let me know what they are.
14-05-2014 7:39 PM
Have you got a method of storing those files and folders? E.g. spare HDD.... big memory stick...
IF yes to both.... get a copy of Linux Mint downloaded, and burned to DVD...
run the Linux mint on the DVD... then recover your folders and files to the memory stick... spare HDD...
Then format the original HDD and re install W7.... and XP if you must as dual boot....
14-05-2014 7:58 PM
If not, and I dont understand why I cannot get XP re-installed, I will try to get Win 7 going again, and load all the process software on the Win 7 partition.
Eventually, I plan to go to just Win 7 - that may happen sooner than I wanted.
Regards
14-05-2014 9:38 PM
Quote from: penneck I dont understand why I cannot get XP re-installed,
The most likely explanation is that your hard disk drive is faulty and a proportion of the files copied to it end up corrupt. You can test this theory by booting from one of your installation discs and running the full five-stage chkdsk on your XP partition.
15-05-2014 6:10 PM
All went well until I tried to install CutePDF Writer. That tried to install 'secure.conduit.com' but I spotted where I could prevent that. However some unexpected downloads got through including a Norton security program, but I managed to get all of these uninstalled. The only problem now is an icon called Live PC. I don't know where that came from nor how to get rid of it, so if you know please respond. In the meantime I am going to search on Google for the answer
15-05-2014 7:09 PM
15-05-2014 7:34 PM
15-05-2014 7:40 PM
As an aside, I seem to be timing out on this site in about 3 minutes - where can I adjust this?
15-05-2014 7:45 PM
- « Previous
- 1
- 2
- Next »
