Unrequested changes to Internet Explorer
- Unrequested changes to Internet Explorer
11-05-2014 7:32 AM
Is there something I can do to 'fix' this?
Re: Unrequested changes to Internet Explorer
11-05-2014 8:32 AM
http://malwaretips.com/blogs/remove-conduit-apps-search-and-toolbar/
11-05-2014 9:34 AM
A common practise these days is to install a whole package of unwanted junk programs, including ones that claim to do backup, speed-up your computer and check for "errors". You'll need to uninstall them all if this has happened to you. In Windows 7 the date of installation can help to give away the identity of these programs.
11-05-2014 4:04 PM
11-05-2014 4:52 PM
Also,... remember when downloading and installing progs from the net.... always choose "Custom Install"... and you can "decline" all the "extras" that you would have ( did get) got by using the "express" ( already chosen for you by default ). install...
11-05-2014 5:42 PM
11-05-2014 6:17 PM
I seem to remember there was a program a while back that was a popular utility that, even though custom was selected, the junk was still installed anyway
Quote from: shutter Also,... remember when downloading and installing progs from the net.... always choose "Custom Install"... and you can "decline" all the "extras" that you would have ( did get) got by using the "express" ( already chosen for you by default ). install...
Forum Moderator and Customer
12-05-2014 6:59 AM
hence Malwarebytes
@ penneck if you can run" Regedit " and are fairly confident bet you will find lots of keys for conduit in there
or there are some software registry checks around
http://www.techsupportalert.com/best-free-registry-editor.htm#Registrar-Registry-Manager-Lite-Editio...
12-05-2014 5:19 PM
Will load Malwarebytes - it seems to get a lot of good press in the PlusNet forum.
Thanks to all for the help
12-05-2014 5:53 PM
12-05-2014 7:28 PM
When it eventually finished, I could, and still can, boot up in either XP or Win 7. However, now when I boot up in Win 7 everything seems to work okay, but it complains that the Recycle Bin on Drive 😧 (the XP drive) is corrupt. If I boot up in XP everything seems to work including Spybot, Google Earth and Mailwasher, but Internet Explorer wont start at all. Admittedly, after I close Google Earth, it produces a "Google Earth has a fault and needs to shut down" message. I can live with that but I would like to get IE working again. I suppose I need to insert my XP CD in the DVD drive and run repair, but I have never had any success doing that, and I would rather not have to go back to a full XP Install.
If you are wondering how I am sending this message if XP IE isn't working, I am in Win 7 IE. 8¬)
Any suggestions please?
12-05-2014 7:50 PM
12-05-2014 8:21 PM
XP comes back with the message " System Restore is not able to protect your computer. Please restart your computer and then run System Restore again". I tried again, but same result.
Any other suggestions?
12-05-2014 11:01 PM
Quote from: penneck Win 7 says there isn't a Restore Point.
On an XP/Win 7 dual boot system the act of booting to XP will obliterate any Windows 7 restore points. The only way around this is to prevent XP from seeing the partition that holds Windows 7.
13-05-2014 4:55 PM
I'm seriously thinking of running XP Repair later. I will go past the first place where the XP installation CD offers Repair to the next point it offers it. I understand it will then do an install without formatting the hard drive, and without losing any other software on it. Any reason why I shouldn't?
