Unlocking the potential of Sagemcom 2704N
- Unlocking the potential of Sagemcom 2704N
Re: Unlocking the potential of Sagemcom 2704N
07-03-2016 9:06 AM
Quote from: Matty123123 cheers guys/gals.
Hi Matty, I've been following what you've done, I have a V2 router and installed v3B of your firmware, I read that you no longer recommend this firmware vs the new official one? Why is that? Also, what is the easiest way to roll back to version 7.275.2 as I can't see the download anywhere? Can I update to the older official firmware, then have TR069 update it to the latest?
07-03-2016 2:24 PM
I can not find a download for any Plusnet 2704n firmware. This looks like it might have it, but I can not guess what the correct html page is.
http://products.plus-payh.co.uk/firmware/2704n/???something???
Also, it appears that the firmware might need adjusting before its uploaded to the router...
If anyone does manage to guess the correct page... please post it
I have tried that idea, I downgrade to the stock firmware and left TR069 on for 1 day and it did not work for me. However, for all I know they probably blocked me (so I don't play about with there software again) but it might work for you?
07-03-2016 5:31 PM
I had no trouble whatsoever with the v1 firmware as far as DSL stability was concerned, it was excellent (3km line).
The v2 firmware is even more locked down, and you can't get a text config from it to play with. I don't see any reason why people shouldn't continue (at their own risk of course) to use your modified firmware.
The only point to note (that I'm aware of) is that the TR-069 will be expecting to find the version number, identification etc and serial number exactly as it was when issued, otherwise TR-069 won't work. Is TR-069 not working such a big deal?
Of course anyone who alters the firmware from that as supplied by Plusnet cannot necessarily expect any firmware upgrade that Plusnet might push in the future, to work.
In the past Plusnet have not pushed firmware upgrades out to the wider customer base, but strangely they have recently done so for the TG582n with some rather annoying (to say the least) consequences for unsuspecting and unknowledgeable customers, so I don't think they are likely to do it again in a hurry without being considerably more careful!
@bjt
Hi there and welcome to the forum. Unless Matty comes back with something definitive, if your current performance with his firmware is ok, then I wouldn't worry about it. Stay as you are.
07-03-2016 7:52 PM
"plus-payh.co.uk" - is owned by Plus-net. And there is definitely a directory called "/2704n/". I was just guessing what the firmware name could be (based off the other TG58* files already there)
...If the new version 2 does not increase stability, then I hope it fixes some security flaws ?
07-03-2016 8:22 PM
This is what I was told
Quote The only difference in the newer version of the firmware is that the MTU is set to 1492 out of the box and there is a system log that’s been removed, nothing more substantial.
Whatever that log was, and whatever got removed it prevented a download of the text config.
08-03-2016 10:04 AM
Quote from: Matty123123 Hello, I recommended not to use this firmware because Its based on ver1 (7.273.1) not ver2 (other+). And I'm "assuming" the ver2 probably has a more stable DSL connection.
If anyone does manage to guess the correct page... please post it![]()
Thanks for the quick reply! So, I installed your 3B firmware then saw your comment that you didn't recommend it so decided I'll try and roll it back. I installed the stock version 1 firmware then changed the serial number and MAC back to the original, called Plusnet yesterday afternoon and asked if they could push out the new firmware, and about 2 minutes ago it just updated back to 7.275.2. So gone full circle. I guess now I know the old firmware isn't much different, maybe I'll go back to yours again!
08-03-2016 11:21 AM
EDIT:
P.S. I'm impressed with the plusnet staff. Normally I do not bother to phone companies with technical questions.
08-03-2016 1:58 PM
[Moderator's note by Dick (Strat): Full quote of preceding post removed, as per Forum Rule]
08-03-2016 6:42 PM
I was just curious... because my firmware attempts needed to rewrite the boot-loader, which I did not want to do. And I wanted to know if a remote update changed it (normally it should not).
It appears the Wireless & DSL drivers don't change.
I think I might update my router when I fix my main computer again. (P.S. don't buy MSI motherboards, its my 3rd one now)
13-04-2016 1:31 AM
Matty 123123 I'm from Brazil and installed the firmware on my modem's that Sagemcom 2704n is working fine, but I wonder how I can return to the original firmware from my ISP? Thank you in advance !!!
17-04-2016 11:14 AM
Hello, Sorry I have no idea how to do that.
Can you provide a link to the firmware from your ISP? I'll have a look to see if its possible.
17-04-2016 12:47 PM
17-04-2016 1:03 PM
good thinking, well done
19-04-2016 1:33 PM
Can adblock be added to the Sagemcom using either openwrt or by updating to the sagemcom firmware? which version would work best?
19-04-2016 11:36 PM
adblock, naaa... The closest to an adblock (on the plusnet firmware) would be to add website blocks like ".ads.", ".facebook.co", ".amazon.co".
Dont bother with openwrt.
