Uninstall problem
- Re: Uninstall problem
Uninstall problem
02-06-2008 10:09 PM
I'm trying to uninstall Palm Desktop (very like MS Outlook, used with Palm PDA) but I get "internal error 2738" I understand this is a very common broken dll, googling the message leads me to a "fix" with RegCure, which I have already had for some time, and doesn't fix it.
Anybody help please?
1 REPLY 1
03-06-2008 7:22 AM
Without googling your error in particular, the Windows Installer CleanUp Utility might be what you need
paul
paul
