Unified Extensible Firmware Interface (BIOS replacement)
Fixes: 57
http://www.bbc.co.uk/news/technology-11430069
Change to 'Bios' will make for PCs that boot in seconds
Except for the operating system of course  Grin
Fixes: 13
Re: Unified Extensible Firmware Interface (BIOS replacement)
A bit like starting your car quicker, but being unable to get out of your driveway because the bin lorry is there !  Cheesy
pierre_pierre
Thats Rubbish Gery
Fixes: 13
so is your spelling Piere. ! ! !    Cheesy Grin
pierre_pierre
I like winding you up
Fixes: 13
To get back on topic...... this thread is about winding up pc`s and laptops...... not me !  Cheesy
VileReynard
Seasoned Pro
Fixes: 9
What's this got to do with Windows anyway?
Fixes: 57
Since Linux boots up so quickly anyway the first comment wouldn't have been applicable  Roll eyes
VileReynard
Seasoned Pro
Fixes: 9
True - my PC sits in BIOS for a several seconds, then waits whilst the disks spin up.
Actual boot is around 8 seconds.
Login is about 5 seconds (to fully operational).
Waldo
The introduction of UEFI to PCs sounds like a good opportunity to ditch the MBR in favour of GPT and have PCs finally catch up with Apple Macs.
(Shouldn't this be in Hardware?)
magnetism2772
no The BIOS is a piece of software
pierre_pierre
a Bit - hard to understand
Waldo
Quote from: giro
But not Windows software.
I'm posting this from a MacBook; it has an Intel Extensible Firmware Interface. One might reasonably argue that firmware is also, at least in part, software.
Does this mean that discussion of (U)EFI is better suited to the Mac(/Linux) Software forum?
I would argue not; the relevant software is not MacOS related.
In the context of this thread both BIOS and UEFI are much more closely associated with the system hardware than whatever OS may be installed.
Fixes: 57
Ideally a general computer discussion board would have covered it but as it isn't a physical item but a piece of software or firmware on the motherboard this seemed to be the best of a bad job
VileReynard
Seasoned Pro
Fixes: 9
Well Windows is certainly a bad job.  Grin Grin Grin
