Unable to ping US websites
MickKi
For some months now it seems that US ISPs have changed their routers and drop ICMP packets to many websites/hosted accounts across the pond.  You can try your own, but this is a typical result:
ping -c 2 www.networksolutions.com
PING www.networksolutions.com (205.178.187.13) 56(84) bytes of data.
--- www.networksolutions.com ping statistics ---
2 packets transmitted, 0 received, 100% packet loss, time 1010ms
traceroute -n -I www.networksolutions.com
traceroute to www.networksolutions.com (205.178.187.13), 30 hops max, 40 byte packets
1  10.10.10.1  7.356 ms  7.778 ms  8.496 ms
2  195.166.128.101  27.252 ms  33.192 ms  33.478 ms
3  84.92.4.242  78.932 ms  79.032 ms  79.468 ms
4  213.200.78.69  42.642 ms  47.090 ms  48.601 ms
5  89.149.187.66  121.731 ms  124.022 ms  125.553 ms
6  206.24.193.197  139.469 ms  136.239 ms  137.938 ms
7  204.70.193.2  129.162 ms 204.70.193.54  133.556 ms  129.768 ms
8  204.70.196.101  118.231 ms *  109.948 ms
9  204.70.196.178  110.372 ms 204.70.196.170  98.070 ms 204.70.196.178  101.940 ms
10  204.70.195.157  102.815 ms  96.725 ms 206.24.232.161  95.932 ms
11  204.70.196.169  100.427 ms  99.473 ms  103.174 ms
12  204.70.197.74  101.992 ms  98.766 ms  99.779 ms
13  204.70.197.17  105.639 ms  107.736 ms  109.374 ms
14  216.33.98.3  107.260 ms  99.162 ms  100.988 ms
15  * * *
16  * * *
17  * * *
18  * * *
19  * * *
20  * * *
21  * * *
22  * * *
23  * * *
24  * * *
25  * * *
26  * * *
27  * * *
28  * * *
29  * * *
30  * * *
mtr -c 3 -n -r www.networksolutions.com
HOST: lappy                      Loss%  Snt  Last  Avg  Best  Wrst StDev
  1. 10.10.10.1                    0.0%    3    1.3  1.8  1.3  2.6  0.7
  2. 195.166.128.101              0.0%    3  25.1  24.6  23.2  25.4  1.2
  3. 84.92.4.242                  0.0%    3  24.1  24.3  24.1  24.6  0.3
  4. 213.200.78.69                0.0%    3  23.6  34.8  23.6  55.2  17.7
  5. 89.149.187.62                0.0%    3  91.7  92.3  89.7  95.3  2.8
  6. 206.24.193.197                0.0%    3  103.0 104.4 103.0 105.7  1.3
  7. 204.70.193.2                  0.0%    3  92.1  93.1  92.1  94.1  1.0
  8. 204.70.196.106              33.3%    3  97.6 102.6  97.6 107.6  7.1
  9. 204.70.196.170                0.0%    3  96.7  96.7  96.6  96.8  0.1
10. 204.70.195.157                0.0%    3  98.6  97.1  96.1  98.6  1.3
11. 204.70.196.169                0.0%    3  99.0  98.9  98.4  99.3  0.5
12. 204.70.197.74                0.0%    3  98.5  98.2  97.4  98.7  0.7
13. 204.70.197.17                0.0%    3  106.4 106.5 106.4 106.6  0.1
14. 216.33.98.3                  0.0%    3  98.5  98.9  98.4  99.9  0.8
15. ???                          100.0    3    0.0  0.0  0.0  0.0  0.0
Have you noticed the same?  Do you know why this is so?
The above makes ping tests impossible and breaks typical connectivity tests run by various applications (e.g. Nagios).
