Unable to login to Plusnet
- Re: Unable to login to Plusnet
07-07-2015 4:42 PM
No problem logging in to the members centre or plusnet webmail but unable to log into the Plusnet main site.
I have had a email reminder and my user name and password are exactly the same, I have tried deleting and then re entering my password but still no luck.
My password for the member centre & webmail are different to the one for the PN main site.
We are born into history and history is born into us.
6 REPLIES 6
07-07-2015 4:45 PM
You must have submitted this as I typed mine out. I too am having issues.
MArk
MArk
07-07-2015 4:46 PM
Invalid username or password here
I think they broke it last night
07-07-2015 5:06 PM
Appears to be working now.
07-07-2015 5:52 PM
Thanks for that, glad they were at fault.
Felt a bit silly posting this query in case the fault was mine.
Even thought I might have been banned from PN as some of my posts can be a bit strong.
07-07-2015 7:56 PM
I'll take a look......it's never too late
07-07-2015 8:10 PM
