Unable to download from FTP
- Re: Unable to download from FTP
11-12-2009 10:19 AM
11-12-2009 2:46 PM
$ telnet ftp.vaio-link.com 21
Trying 213.248.114.178...
Connected to 36871.ftp.download.akadns.net.
Escape character is '^]'.
220 spftp/1.0.0000 Server [213.248.114.178]
telnet> q
Connection closed.
Are you using the Plusnet firewall (accessed from the Member Centre)? I think that blocks port 21
I guess you could try the downloads section of the Vaio Support web site for the updates you're looking for.
11-12-2009 4:22 PM
I'll try the telnet. I'm not using the PN firewall, only that built into the router. I've already tried the direct download route with no success.
11-12-2009 4:26 PM
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\VGNAW41MF>cd\
C:\>telnet ftp.vaio-link.com 21
'telnet' is not recognized as an internal or external command,
operable program or batch file.
How exactly do I use telnet?
11-12-2009 4:47 PM
11-12-2009 4:56 PM
I get this line and a flashing cursor below and nothing else happens,
What does it mean?
11-12-2009 5:15 PM
If your firewall is still running it isn't blocking port 21.
Back to the drawing board on why your updates are failing, I guess
13-12-2009 2:38 PM
13-12-2009 8:24 PM
Worth checking if this is the case with your model (if you still have it).
14-12-2009 10:59 AM
Thanks very much indeed and have a happy Christmas.
