Unable to delete file in W7
- Unable to delete file in W7
15-05-2010 8:25 PM
Quote The action can't be completed becuase the file is open in Windows Explorer
Quote The action can't be completed because the foldder or a file in it is open in another program
Google hasn't found any suitable solution as yet.
I have installed the latest version of Unlocker but that doesn't even show up on right-clicking on the file/fiolder like it did in XP.
Has anyone else found a solution fpr this in W7 64 bit?
Forum Moderator and Customer
Re: Unable to delete file in W7
15-05-2010 8:57 PM
15-05-2010 10:05 PM
16-05-2010 9:00 PM
18-05-2010 12:28 AM
29-05-2010 6:01 PM
or Linux
29-05-2010 6:55 PM
Edit: here it is.
30-05-2010 10:33 AM
Quote from: Waldo I'd try deleting them from the command line (but I've never used W7)
Nope - didn't twork.
Quote from: Denzil Unlocker used to be very handy, but it doesn't work in Win 7.
It works OK in 32 bit.
Quote from: severedsolo google a program called Lockhunter, it is the 64 bit version of Unlocker
I'll look for this for future use.
Cheers all.
31-05-2010 1:03 AM
I've stopped thinking about a possible cause,
It is in fact a bug.
M$ unspeakable oaths..
T.
