Unable to connect router to set-top box
Cazsq2021
Hi
As per title, my router is in my hallway and the set-up box is in living room. I'm using powerline adapters in both mains sockets respective to the router and set-top box however it's still not connecting.
Can anyone advise on a way around this. I would like to avoid trailing cables.
Many thanks
Carol
7 REPLIES 7
Fixes: 1,483
Re: Unable to connect router to set-top box
Moderators Note
This topic has been moved from Fibre to Tech Help
Fixes: 419
@Cazsq2021
If the set top box has been connected to a different router then try a factory reset on the set top box and set it up from scratch.
If it’s a new set up see this https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Powerline-Unit-Performance/m-p/1607450...
Cazsq2021
@Baldrick1
Hi
Thanks for your reply. The router and set-top box are both the same however following a room refurb and movement of sockets I moved the telephone line to the Hallway as it was originally in the living room. I didn't think this would affect the signal.
Any thoughts?
Thanks again
Fixes: 1,483
Don't suppose the powerline adapters are on a different wiring ring?
Cazsq2021
Hi Dvorak
Unfortunately I haven't a clue about that one.
Fixes: 419
@Cazsq2021
 Then click on the link in my earlier post and you will learn how to find out.
Cazsq2021
Thanks I will.
