Unable to connect router to set-top box
- Re: Unable to connect router to set-top box
26-05-2021 1:07 AM
As per title, my router is in my hallway and the set-up box is in living room. I'm using powerline adapters in both mains sockets respective to the router and set-top box however it's still not connecting.
Can anyone advise on a way around this. I would like to avoid trailing cables.
Many thanks
Carol
26-05-2021 7:12 AM
Moderators Note
This topic has been moved from Fibre to Tech Help
26-05-2021 10:03 AM
If the set top box has been connected to a different router then try a factory reset on the set top box and set it up from scratch.
If it’s a new set up see this https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Powerline-Unit-Performance/m-p/1607450...
26-05-2021 11:03 AM
Hi
Thanks for your reply. The router and set-top box are both the same however following a room refurb and movement of sockets I moved the telephone line to the Hallway as it was originally in the living room. I didn't think this would affect the signal.
Any thoughts?
Thanks again
26-05-2021 11:21 AM
26-05-2021 11:41 AM
Unfortunately I haven't a clue about that one.
26-05-2021 12:35 PM
Then click on the link in my earlier post and you will learn how to find out.
26-05-2021 1:52 PM
