Unable to access router's web ui or telnet
- Unable to access router's web ui or telnet
31-01-2015 12:06 PM
After about 30 mins of running fine, my router (Plusnet TG582n FTTC) stops accepting any connections to it's web ui or telnet server. My internet still works okay, but I have to restart my router to be able to change any settings. The issue only happens when I have my secondary TG582n router running as a secondary AP. I am assuming the issue is because they are both trying to use the same ip/domain, but I have checked both and they use completely different IP addresses, and I removed the 'dsldevice.lan' DNS registration from the user.ini config file. I followed the http://npr.me.uk/together.html tutorial when setting this up.
1 REPLY 1
Re: Unable to access router's web ui or telnet
24-02-2015 7:22 PM
I have the same issue
I have it even with just a single router on the network
I have given up trying to fix it
the router is just rubbish
