Unable to access particular website
Claremac
Hi
Hope someone can help me as I haven't been able to access a website at http://forums.moneysavingexpert.com/ ; from either of my PCs for the last 3/4 days. I can access the main website at www.moneysavingexpert.com but not the forum even if I go through the main website. This is a real pain as I am moving house in 4 weeks and am getting lots of good advice there. I have had a few problems with it in the past but it has always been OK after a few hours.
I have tried deleting temp files, flushdns, turned the Windows firewall on and the Panda one off to try again and still no go. Please can anyone suggest anything I could try? Many thanks.
Clare
14 REPLIES 14
pierre_pierre
Re: Unable to access particular website
I am using Firefox and have just accessed both sites
I am currently connected to the "Telehouse North, Juniper 1" gateway. This gateway is sometimes known as ptn-ag1.
Fixes: 1,483
It's working ok here, my OH is addicted to it. I remember that i had the same issue a while ago and it just righted itself
What happens if you run a tracert on it? I get:
Tracing route to forums.moneysavingexpert.com [213.129.82.53]
over a maximum of 30 hops:
 1     1 ms     1 ms     1 ms  192.168.0.1
 2    37 ms    34 ms    40 ms  lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
 3    35 ms    35 ms    35 ms  ge0-0-0-504.pte-gw2.plus.net [84.92.4.90]
 4    35 ms    34 ms    37 ms  vl23.thn-gw2.plus.net [212.159.4.20]
 5    34 ms    34 ms    34 ms  te2-3.thn-gw1.plus.net [212.159.1.57]
 6    36 ms    33 ms    34 ms  linx2.ukcore.bt.net [195.66.226.10]
 7    36 ms    36 ms    36 ms  core2-pos0-0-0-10.ealing.ukcore.bt.net [62.6.204.93]
 8    35 ms    35 ms    35 ms  62.6.204.94
 9    35 ms    35 ms    35 ms  interconnect2-gig2-0.kingston.fixed.bt.net [194.72.3.69]
10    39 ms    37 ms    38 ms  ftip002860169.interconnect2.kingston.fixed-nte.bt.net [6
11    38 ms    38 ms    48 ms  bgp-gw-1-ge0-2.ash.core.thebunker.net [62.6.152.186]
12    38 ms    39 ms    38 ms  ash-abr-1-a.ash.thebunker.net [213.129.64.238]
13    38 ms    37 ms    38 ms  ash-ce-1-a.thebunker.net [213.129.78.1]
14    39 ms    38 ms    38 ms  mse-vip-1.hosted-at.thebunker.net [213.129.82.53]
Trace complete.
Claremac
Hi guys, thanks for the responses. I should have said that I know that it's not a problem with the website as I asked a friend to try it. I have to confess to not knowing what a Tracert was  Roll_eyes but I looked it up and hope I got it right. The result was that from 14 to 30 I got Request Timed Out. (I would have cut and pasted but it won't let me.) Does this tell me anything? Actually, that should read "Does that tell you anything?" as it tells me nothing Grin
ddunford
Claremac,
Have you tried emailing the web master of the site to ensure they have no blocked your IP address? just a thought as i cant think of anything else that would stop you from browsing to that particular site as i presume everything else about your connection is fine?
paulby
I had a similar problem with that website which was resolved by changing the MTU on my PC to 1430.
Try following the advice here and see if things improve.
James
I can definitely access those forums.
I spend large amounts of my day in there.
Fixes: 1,483
Quote from: Jameseh
Hope your boss doesn't read this then Wink
James
Erm, it's part of my job...
jelv
Fixes: 10
Have you tried fiddling with your MTU - that sometimes comes in to play with people being unable to access particular sites.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
shutter
Fixes: 65
Have you got Roman ancestors...... spending so much time in forums ?  Roll_eyes
Claremac
Thanks for the ideas. I tried changing the MTU but nothing changed. I have emailed the webmaster so I'll see what they say. Everything else about the line is OK (not as fast as I'd like but hey ho  ;D)
Claremac
Unfortunately I received an automated email from the Webmaster saying that as they had thousands of emails a day they could not respond individually and gave a list of FAQs including a link to FAQs for the Chat forums which (you guessed it) I can't access! Does anyone have any further ideas please?
godsell4
Reboot your router, you may have done it and not mentioned it, neither has anybody else suggested it ... worth a try?  Wink
3Mb FTTC
Claremac
I suddenly remembered that I hadn't replied on here that I had fixed the problem  :), came on to say so and guess what? There was the answer!  Grin Yes, Godsell4, it was the router and I had eventually realised that that was the one thing I hadn't tried. Thanks for suggesting it anyway and I hope that it may help someone doing a search on a similar subject in the future.
