Ubuntu wins new award
- Ubuntu wins new award
29-10-2013 10:33 AM
Quote Canonical’s decision to add Amazon product suggestions to the Unity desktop has seen the company presented with a ‘Big Brother Award‘ in Austria.
The controversial feature – which uses local search terms to fetch ‘relevant’ product results from the web – was announced as a winner of the un-coveted prize at a ceremony in the Austrian capital, Vienna, on Friday, October 25th.
The Big Brother Awards – held annually since 1999 – hands out gongs to governments, companies, persons and projects deemed to “have done the most to invade personal privacy”. This can take the form of misusing, violating, or disclosing personal data to third parties.
Awards are handed out to projects that ‘invade personal privacy’.
The award marks the latest public admonishment of the shopping lens.
Don't use Ubuntu and will NEVER use unutty
Re: Ubuntu wins new award
29-10-2013 10:23 PM
Just because Canonical have f**ked up doesn't mean that Ubuntu derivatives are dodgy.
30-10-2013 10:11 AM
31-10-2013 6:55 AM
I like it on Arch (web searches are disabled by default).
31-10-2013 12:53 PM
Why do they do that?
01-11-2013 3:19 PM
01-11-2013 3:48 PM
YouTube video - How to Disable Amazon Results in Ubuntu Unity Dash
That is even more ridiculous than abandoning Ubuntu because the default GUI is Unity, when all you have to do is click on the "Software Centre" hit install "Gnome Desktop", logout, login using Gnome, and from then on your default desktop is classic Gnome.
If doing that through the "Software Centre" is too hard, then simply run this in a terminal, and then restart -
sudo apt-get install gnome-session-fallback
What's the big fuss over such insignificant and trivially easy things to set as you want ?
01-11-2013 4:02 PM
Quote from: purleigh That is even more ridiculous than abandoning Ubuntu because the default GUI is Unity
I quit using Ubuntu many many years BEFORE unutty was introduced.
Quote from: 30FTTC06 in all honesty i think using mint is going backwards!.
Hmm interesting, I prefer Mint because EVERYTHING works, from DVD playback to mp3 players. I don't HAVE to install any extra codecs to get banshee to play mp3's for instance which was true last time I used Ubuntu.
I am not alone either, Mint has replaced Ubuntu as the #1 distro.
02-11-2013 1:59 PM
then you are stuffed in Unity.
At least if you know roughly what it does you can find it (quickly) on a menu.
If Ubuntu are forwarding local searches through the internet to Amazon, then what else are they doing?
It's a loss of confidence thing.
02-11-2013 4:44 PM
tbh say what you want, Ubuntu has done a lot to bring linux into the present as a user friendly OS
Personally I don't like Unity, but then the ubuntu base is very stable, and the beauty of linux is, once you have a stable base, you can build and tailor the OS to suit yourself
02-11-2013 4:48 PM
02-11-2013 8:14 PM
I still use it for server stuff but can't stand all the bloatware that comes with the Desktop version now - I tend to install the server version then XFCE4 or similar so I can find what I've installed
02-11-2013 10:22 PM
03-11-2013 12:11 AM
It's mostly drivers that are the problem or stuff just not working as it should.
It might be ok if you have a really basic computer with onboard graphics and just want to browse but otherwise getting the GPU acceleration working properly is often a dark art.
Use Linux heavily on servers and love it for it's embedded applications but for desktop use it's usually just to much hassle.
03-11-2013 11:19 AM
Quote from: 30FTTC06 I like the layout, thats about it really..
So Cinnamon for you then? I still prefer Mate, don't like the "extra's" that C adds.
@dragon2611 What GPU are you using that causes so much problems? I use NVidia GPU's and have never had any problems, just install the latest driver and you have everything working.
