Ubuntu to drop the free Ubuntu one music & storage
- Re: Ubuntu to drop the free Ubuntu one music & sto...
02-04-2014 6:30 PM
Re: Ubuntu to drop the free Ubuntu one music & storage
02-04-2014 8:12 PM
Buy yourself a disk.
02-04-2014 9:14 PM
07-04-2014 11:52 PM
08-04-2014 2:56 AM
It's 99% unused.
08-04-2014 10:34 PM
I also have lots of storage at other cloud providers but for work purposes I really need a syncing software.
15-04-2014 3:28 PM
15-04-2014 3:33 PM
Quote from: AverageWhiteBloke The problem with drop box is you have to put your folders into the Dropbox folder as opposed to one where you can select folders to sync.
You can just sym link them in (If using an OS that supports sym links)
15-04-2014 4:07 PM
Much faster and more secure.
15-04-2014 5:08 PM
Quote from: vilefoxdemonofdoom Buy yourself a portable hard disk for backups.
Off-site backup has its merits though, especially at £5.97* per month for a TB.
*Today's rate according to Google
15-04-2014 7:26 PM
http://sr71.net/projects/gmailfs/ allows you to use a Gmail account as a remote File System.
Cost = nothing.
Features encryption where you don't have to give the key to Dropbox.
Alternatively, there's the unencrypted Google Drive...
15-04-2014 8:47 PM
If I do need encryption and it doesn't support it natively there are probably tools available and I suppose there is nothing against uploading TrueCrypt volumes, except maybe file size limits. The independent audit is partially complete now, too.
16-04-2014 10:41 PM
Quote You can just sym link them in (If using an OS that supports sym links)
I've been doing a bit of reading up on that. Some other good options to look into here as well. I use Drop Box and previously Ubuntu One for work. Being cross platform is a major selling point for me and unusually for anything Linux there was an Ubuntu one app for every device I use. It's not as much as cloud storage I need rather the ability to edit a document and have that synced across multiple devices as I work on it. I also have much more cloud storage space with other suppliers but no syncing tool that I can use for larger unimportant files.
01-05-2014 4:57 PM
What do people think of the F-Secure offering - given that it is in a EU country and free from interference perhaps from the US !!!.
I tend to trust the Finnish more than many other nations.
Mal
01-05-2014 9:31 PM
I'm using SpiderOak now - not as good, but it's good enough for me as I just use it to sync a low volume of files.
