Ubuntu and wireless access
- Re: Ubuntu and wireless access
21-02-2008 7:33 PM
I have a dual boot desktop PC running XP and Ubuntu. Until recently I was connected by ethernet cable to my router. Following a line problem, the BT engineer installed a new Openreach box with separate sockets for phone and ADSL. This is located at some distance from the PC so I now have to access via wifi.
I am using a USB Zonet ZEW2500P which connects OK on XP. However, on Ubuntu although it can see my own network (and three others), when it tries to connect it asks for my WEP Passkey, which I have tried entering as 128 bit hex and 128 bit ascii. But neither will work. I have double checked with the router (via XP) that I am using the correct code, but have not managed to get it to connect at all.
Does anyone have any suggestions please?
21-02-2008 9:29 PM
22-02-2008 10:35 AM
https://help.ubuntu.com/community/WifiDocs/WirelessCardsByVersion
22-02-2008 2:31 PM
axisofevil - I have the wireless connection working perfectly under XP, but not with Ubuntu. The only difference in the link you gave is that they are suggesting WPA and I am using WEP.
denzil - unfortunately, the link consists of 99 pages. After reading a number of them it seems that the guidance given doesn't work for everyone, and on page 99 there are still people with outstanding problems similar to mine. I am a complete novice with Ubuntu and don't feel confident enough to make significant changes which might have to be reverted.
At present I have no internet access to Ubuntu as the router is on a different floor and there is no practical way of connecting by ethernet.
22-02-2008 4:12 PM
Due to lack of linux drivers. Ubuntu allows you to use a Windows driver - presumably XP?
I haven't done it myself as Ubuntu handles wifi with Atheros (and some others) chipsets.
You may want to try:-
http://ubuntuforums.org/showthread.php?t=205026
The individual steps are very simple - do you know how to use sudo in Ubuntu?
22-02-2008 7:45 PM
As far as I can tell, it has installed successfully, as I can see the driver associated with the hardware. However, when I boot up, it doesn't search for any networks. I've used the command 'sudo ndiswrapper -m' (which I believe associates an alias for startup?) and get the response 'module configuration already contains alias direction'.
File '/etc/network/interfaces' contains the following -
auto wlan0
iface wlan0 inet dhcp
wireless-key HHHHHHHHHHHHHHHHHHHHHHHHHH
wireless-essid XXXXXXXXXXXXXX
(with the correct SSID and key of course)
So far I haven't been able to find out how to start the network. So one step forward and two steps backward!
To answer your question, I know how to enter sudo commands as long as they are specified in full. I don't profess to understand what they mean.
23-02-2008 12:47 AM
Have you tried using a fixed ip address?
My /etc/network/interfaces file reads (ignore the ======):-
auto lo
iface lo inet loopback
iface ath0 inet static
address 192.168.0.5 <-- My IP address
netmask 255.255.255.0
gateway 192.168.0.1 <-- My router address
wireless-essid SSSSSSS
wireless-key KKKKKKKKKK <-- In hex
wireless-rate 54M
# Next 4 lines are for disconnected ethernet
iface eth0 inet static
address 192.168.0.6
gateway 192.168.0.1
auto ath0
Note that interface names (ath0, eth0, wifi0...) seem to be very variable.
I downloaded ndiswrapper and entered
ndiswrapper --help
It said:-
usage: ndiswrapper OPTION
-i inffile install driver described by 'inffile'
-a devid driver use installed 'driver' for 'devid' (dangerous)
-r driver remove 'driver'
-l list installed drivers
-m write configuration for modprobe
-ma write module alias configuration for all devices
-mi write module install configuration for all devices
-v report version information
This sounds slightly different to sudo ndiswrapper -m
I have never used this - but I would be tempted to tentatively!!! try
ndiswrapper -l
sudo ndiswrapper -ma
reboot
Stop at the ndiswrapper -l if it doesn't show what you expect though!
If it's any consolation Netgear (PCI card) work without any configuration.
P.S. If you have a 64 bit Ubuntu, the procedure is slightly more complicated for ndiswrapper.
23-02-2008 11:17 AM
I have some work to do on XP this morning, but will check it out again this afternoon.
Thanks.
23-02-2008 2:56 PM
ndiswrapper -l displayed
rt2500usb: driver installed
device 148f:2570 present (alternative driver: rt2500usb)
ndiswrapper -ma displayed
module configuration information is stored in /etc/modprobe.d/ndiswrapper
Windows Network Drivers shows
rt2500usb
Hardware present: Yes
However, when I look at Devices - Network Tools, I notice the following -
in the drop-down menu for Network Device, there is an entry
Wireless interface (wlan0)
but the Interface information shows as 'not available' on every item.
If I select 'Configure' it displays 'wlano Properties' with all the fields correct
Also in the drop-down menu (immediately under the wlan0 entry) is another entry
Wireless interface (wlan0:avahi)
the Interface information shows the correct Hardware (MAC) address, Multicast: Enabled
MTU: 1500, Link speed: 11 Mbps, State: Active.
However, selecting 'Configure' for this item displays "Interface does not exist - Check that it is correctly typed and that it is correctly supported by your system".
I don't know how AVAHI crept in, but somehow the information seems to be split between the two entries.
As it stands at present, when I boot up, the network doesn't try to connect. The Network Settings show Wireles Connection enabled.
23-02-2008 6:00 PM
lshw -C network
*-network
description: Wireless interface
physical id: 1
logical name: wlan0
serial: (my MAC address)
capabilities: Ethernet physical wireless
configuration: broadcast=yes driver=ndiswrapper+rt2500usb driverversion=1.45+Railink, 05/21/2004, 1.00.01 link=no multicast=yes wireless=IEEE 802.11g
iwlist scan
wlan0 scan completed
It then shows wireless networks of the neighbouring property and my own:-
Cell 01 ESSID AAAAAAAAAAAAA
Cell 02 ESSID MYNETWORK
Protocol IEEE 802.11b
iwconfig
wlan0 IEEE 8022.11g ESSID MYNETWORK
AccessPoint: Not Associated
Encryption Key: MYMACKEY
Hope this information is helpful
23-02-2008 10:15 PM
23-02-2008 11:46 PM
The USB connection doesn't help though.
My Netgear WG311T (a PCI card) works (without any configuration) with my Netgear router.
It's worthwhile finding out the chipset a wireless card uses and checking with Google if any problems have been reported for either the card or the chipset.
If it's of interest
jeremy@HECTOR:~$ sudo lshw -C network
*-network
product: AR5212/AR5213 Multiprotocol MAC/baseband processor
vendor: Atheros Communications, Inc.
physical id: 8
bus info: pci@0000:05:08.0
logical name: wifi0
version: 01
serial: [MAC ADDRESS]
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list logical ethernet physical wireless
configuration: broadcast=yes driver=ath_pci driverversion=0.9.4.5 (0.9.3.2) ip=192.168.0.5 latency=168 maxlatency=28 mingnt=10 module=ath_pci multicast=yes wireless=IEEE 802.11g
Works fine for me.
24-02-2008 11:51 AM
24-02-2008 2:52 PM
I rebooted, and the network came up like a dream and connected to my router. So I am now able to access the internet again. I have no idea why, but I am going to leave well alone.
Many thanks for your help.
24-02-2008 3:48 PM
