Ubuntu 8.10
- Ubuntu 8.10
- « Previous
- Next »
Re: Ubuntu 8.10
06-12-2008 7:22 PM
Ubuntu extras / assistance wiki's:-
8.04 - the long-term stable version:-
http://ubuntuguide.org/wiki/Ubuntu:Hardy
8.10 - Latest stable version:-
http://ubuntuguide.org/wiki/Ubuntu:Intrepid
E&OE
E&OE
Re: Ubuntu 8.10
06-12-2008 7:46 PM
I am just working throught the 8.10 document.
It is interesting that the ATI drivers section is blank!!
Re: Ubuntu 8.10
07-12-2008 1:37 AM
Quote from: Santiago I have just updated to 8.10. [It took a long time to download and install.]
Everything appears to be working ok except Ubuntu will only run in low graphics mode and I am struggling with installing the ATI graphics card driver.
I had exactly the same problem with my Nvidia drivers when I upgraded from 8.04 to 8.10. Eventually I gave up, reformatted and did a clean install with 8.10, drivers worked fine again after that.
Re: Ubuntu 8.10
07-12-2008 12:00 PM
Ditto that.
I gave up too in the end. I did a clean install and everything works fine [Ekiga is not set up yet though]
The clean install and restoring backed up profiles only took a fraction of the time the upgrade took.
So you live and learn
Re: Ubuntu 8.10
11-12-2008 9:43 PM
Can't update Nvidia drivers while running the live CD version as a reboot starts again from scratch
...but I'm liking 8.10 so far
Re: Ubuntu 8.10
11-12-2008 10:02 PM
You would like it even more when you install it. Dual boot is a good way to start.
Re: Ubuntu 8.10
01-01-2009 8:48 PM
Does anyone know how to change the computer name in 8.10?? There was a GUI in 8.04, but this seems to have disappeared in ibex. Upgraded from 8.04, due to issues finding my windows network ( spelt out in another forum, and alsop could not get SWAT to work either). Cannot figure out how to change workgroup and PC name in 8.10.
Re: Ubuntu 8.10
01-01-2009 9:41 PM
You could change your computer name in your /etc/hostname file.
Try
I think you will also need to add this name to your /etc/hosts file.
I suggest you also put your other local machine names in /etc/hosts.
Try
sudo nano /etc/hostname
- « Previous
- Next »
