USB to parallel printer cable
- USB to parallel printer cable
23-07-2015 7:17 PM
Any one have any tips /suggestions/experience of USB to parallel printing? Would this one off ebay do the job?
TIA
Re: USB to parallel printer cable
24-07-2015 1:01 AM
24-07-2015 1:43 AM
Quote from: journeys I suddenly find I need to print to an old A3 parallel printer.
I don't think that includes the actual printer side of the parallel connector - you need a 25 pin (probably) Centronics printer cable.
24-07-2015 5:21 AM
24-07-2015 8:14 AM
Quote from: vilefoxdemonofdoom I don't think that includes the actual printer side of the parallel connector - you need a 25 pin (probably) Centronics printer cable.
Worth a punt at that price though I echo another poster's comment about printer drivers...
24-07-2015 1:46 PM
24-07-2015 2:05 PM
24-07-2015 10:14 PM
Unless you're thinking of computers from the pre to early 80s, that Parallel to USB adaptor is the right way round for operating a Parallel printer on a USB-equipped comptuer...
A regular parallel cable has a DB25 Male plug on the computer end, and the printer end is as pictured, a Male 36-pin "Centronics" Micro-Ribbon connector...
24-07-2015 11:29 PM
24-07-2015 11:57 PM
