USB / Firewire converter?
- USB / Firewire converter?
06-11-2008 9:40 PM
I have a Macbook with a Firewire port on the side, and a Firewire drive to plug in to it... However, I also could do with being able to use this drive on a computer with no firewire ports.
Does anyone know of anything that'd let me plug the Firewire drive in to a USB port?
My knowledge of Firewire is non-existent, unfrotunately.
6 REPLIES 6
Re: USB / Firewire converter?
06-11-2008 9:50 PM
Here is something, though I've never tried one myself
http://cgi.ebay.co.uk/USB-A-Male-to-Firewire-1394-4Pin-Male-Cable-1-5m_W0QQitemZ150262269302QQcmdZVi...
06-11-2008 9:55 PM
That's not the type of connection the drive has unfortunately
06-11-2008 10:17 PM
look here then http://www.maplin.co.uk/family.aspx?menu=1595
06-11-2008 10:20 PM
Couldn't find any on there Pierre, TBH I wasn't sure if it was acutally possible or not.
06-11-2008 10:31 PM
Is the HDD inside accessible? If so, I'd consider buying an enclosure that supports USB and FW and installing the HDD in that - more expensive than a cable would be, but I'm really not sure I'd trust a cable to reliably convert from USB to Firewire as they're pretty different.
07-11-2008 9:11 AM
Any good?
http://www.usbfirewire.com/Parts/rr-527950.html
I'd have serious doubts about it myself for a disk drive.
Is it possible to put a firewire card in the computer you want to connect to?
Regards,
Neil
Regards,
Neil
