USB / Firewire converter?
Colin
I have a Macbook with a Firewire port on the side, and a Firewire drive to plug in to it... However, I also could do with being able to use this drive on a computer with no firewire ports.
Does anyone know of anything that'd let me plug the Firewire drive in to a USB port?
My knowledge of Firewire is non-existent, unfrotunately.
6 REPLIES 6
Fixes: 1,483
Re: USB / Firewire converter?
Here is something, though I've never tried one myself
http://cgi.ebay.co.uk/USB-A-Male-to-Firewire-1394-4Pin-Male-Cable-1-5m_W0QQitemZ150262269302QQcmdZVi...
Colin
That's not the type of connection the drive has unfortunately Sad
pierre_pierre
Fixes: 1,483
Couldn't find any on there Pierre, TBH I wasn't sure if it was acutally possible or not.
Be3G
Is the HDD inside accessible? If so, I'd consider buying an enclosure that supports USB and FW and installing the HDD in that - more expensive than a cable would be, but I'm really not sure I'd trust a cable to reliably convert from USB to Firewire as they're pretty different.
Njal
Any good?
http://www.usbfirewire.com/Parts/rr-527950.html
I'd have serious doubts about it myself for a disk drive.
Is it possible to put a firewire card in the computer you want to connect to?
Regards,
Neil
