USB A connectors
Re: USB A connectors
@penneck
I think the light being on means it's charging from the PC, try turning the camera on
penneck
Ahhh! Found it, and yes it does say Type-C. Sorry my eye sight - I'm getting old
penneck
That did it. I didn't know about the On/Off Switch
Fixes: 583
Yay! we got there in the end
penneck
Werll it looks like I'm going to retain the trophy for 'Plusnet Idiot Of The Year'. All that work and loads of support, and the answer was simple.
My thanks to all of you. I hope you got something positive from this, anot just ulcers.
Regards
Jonpe
Fixes: 9
You mean no-one asked if you'd tried turning it off and back on again?🤣
