USB 2.0 v Firewire
- USB 2.0 v Firewire
USB 2.0 v Firewire
23-01-2009 4:17 PM
Can someone educate me over the simple difference between USB 2.0 & Firewire ? Some external Hard drives mention Firewire connections, is this an advantage over USB 2.0 in terms of speed or anything else ?
We are born into history and history is born into us.
5 REPLIES 5
Re: USB 2.0 v Firewire
23-01-2009 4:33 PM
Both nearly the same, but two different animals and plugs, one wont fit in the other, Firewire stated off on Macs, and Cameras, the original USB was slow, USB 2 is about the same as Firewire
23-01-2009 10:00 PM
23-01-2009 10:06 PM
Provided your computer has a FireWire port, it is always better for an external hard drive than USB 2.0 - if your computer has a FW800 port then if you buy a drive that also supports that you'll be even further ahead of USB 2.0.
23-01-2009 11:04 PM
The key thing is most pc have USB very few have firewire so if you got a Firewire HD your couldn't plug it into every pc like you could a USB.USB 3 should be out soon which will be faster
24-01-2009 1:59 PM
Thanks for the info and links to that website that explains things in detail.
