UPnP
BenG
UPnP
I can anyone tell me is it ok to disable UPnP in my netgear router, at the moment it just has a check box that checked so I take it enabled, I been hereing from people that in Windows UPnP device and SSDP Discovery. Can cause problums in Windows 2000 and XP, Vista
Any advice will be helpfull thanks.
Re: UPnP
Always OFF on my DG834GT. No problems.
Re: UPnP
Always OFF on my DG834G.  No problems here, either.
BenG
Re: UPnP
Thanks I turned it off, rebooted the router and all is working ok
Thanks to both agian for your help.
Fixes: 194
Re: UPnP
If you are a windows MSN messenger user you may find that the file transfer and some other features don't work, though that's probably a good thing Smiley
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
pjemmanuel
Re: UPnP
UPnp off here, running MSN Messenger on 3 PCs on the network, never had a problem with file transfer, voice calls or anything.
Go with the flow, turn it off, you don't need it.
