UPS
UPS
02-08-2014 12:29 PM
I don't particularly need anything too fancy just something that will give enough power to shut down the PC properly.
Is something like this suitable or does anyone have any better, but not too expensive, suggestions?
Forum Moderator and Customer
Re: UPS
02-08-2014 12:51 PM
Cheaper UPS's often use noname batteries which fail after a year or so.
Use it as a device to give you time to save your files then shutdown gracefully rather than hoping the power comes back on before the batteries run out. Also give it a chance to charge back up after the power comes back on as you may get a second power cut fairly shortly after the first while the batteries are in a low condition.
Re: UPS
02-08-2014 2:47 PM
- will run for about 5 minutes at full load (240W) and around 25 minutes at 100W (average for my triple core 3200MHz cpu system)
- it has no data connection for automatic shutdown of the computer/NAS etc, you need the 550 (330W) or 700 (405W) for that - about £13 more (Amazon)
- it is a stepped sine-wave output on battery (good
- if I read it correctly
Phil
Re: UPS
02-08-2014 3:19 PM
but those systems are a bit more expensive this would be an example of something that would fit the bill http://www.play.com/PC/PCs/4-/48838424/819982159/-/ListingDetails.html?gclid=CPanl9Pi9L8CFbDKtAodWEE...
of course if your PSU is lower like a 250w then you could get away with a lower grade UPS
here's a list of links with more info about choosing the right UPs for your setup https://www.google.co.uk/?gws_rd=ssl#q=how+to+choose+the+right+UPS
Re: UPS
02-08-2014 5:40 PM
If I didn't connect the hard dives to any UPS then could I probably get away with a 700W one?
Re: UPS
02-08-2014 5:57 PM
Over several years the capacity of the batteries will steadily reduce, long before the battery fail indicator comes on.
Therefore you might want to consider adding another 50% to 100% to the required capacity rating, if you don't want to be regularly fitting new batteries in order to maintain an underrated capacity.
Re: UPS
02-08-2014 6:07 PM
We're still looking for new property so, hopefully, we'll move to somewhere with a more stable electricity supply.
Re: UPS
02-08-2014 6:20 PM
Alternatively, many eBay sellers remove the batteries from otherwise working UPSes to reduce the shipping charges. These UPSes are often very cheap, but you then have to source your own NEW batteries - although they often end up cheaper than the amount originally saved in posting the UPS !.
The last UPS I installed for my networking kit, cost me £10 from a local seller, the battery lasted about three years before I bought a new replacement OEM battery for £19, and is now good as new. Similarly my 1KW UPS also cost £10 locally, and new batteries for that were £46.
Re: UPS
02-08-2014 6:23 PM
its all about price versus convenience, I found for many years using a UPs was less hassle than loosing documents and replacing parts that broke due to power outages, now I don't care that much and in truth I don't have any critical stuff that's online all the time
Re: UPS
02-08-2014 9:08 PM
Re: UPS
02-08-2014 9:33 PM
Re: UPS
03-08-2014 8:58 PM
Sorry to seem dense, but what do you mean in this context by 'interlink cables'?
Re: UPS
03-08-2014 9:00 PM
