UK supplier of RJ50 plugs.
- UK supplier of RJ50 plugs.
18-10-2014 1:28 PM
I have several APC UPSs and I'd like to create data cables for them. These cables use an RJ50 connector to USB-A with the RJ50 being a 10P10C RJ45!
These plugs are available from the US but I don't really want to bother with that unless I really have to. They can also be got from RS-Online but in packs of 20 and I only need 4 and some spares.
Does anyone know where I can buy these individually in the UK?
Mook
Mook
3 REPLIES 3
Re: UK supplier of RJ50 plugs.
18-10-2014 1:31 PM
You'll also need the crimping tool...
Plugs:
http://www.ebay.co.uk/itm/NEW-RJ-RJ50-RJ48-10P10C-CONNECTOR-IDEAL-FOR-APC-UPS-SCANNER-MANY-MORE-/331...
Alternatively:
http://www.ebay.co.uk/itm/NEW-APC-Simple-Signaling-UPS-Cable-USB-to-WLAN-RJ50-CAT5E-CAT5-RJ45-Enther...
or this one in the UK:
http://www.ebay.co.uk/itm/Original-APC-Smart-UPS-USB-to-RJ50-Communications-Cable-940-0127E-NEW-2m-/...
Plugs:
Alternatively:
18-10-2014 1:43 PM
Farnell will supply them singly http://uk.farnell.com/te-connectivity-amp/5-557963-3/modular-connector/dp/1654823 . I think they've got a minimum order value of £20 though , unless you have a trade account.
18-10-2014 1:49 PM
Hi.
Thanks for that pwatson, just bought two listed on the UK URL at the bottom of your post.
Farnell, I never even thought of them and I've got a CPC account!
Mook
Mook
