UK supplier of RJ50 plugs.
I have several APC UPSs and I'd like to create data cables for them. These cables use an RJ50 connector to USB-A with the RJ50 being a 10P10C RJ45!
These plugs are available from the US but I don't really want to bother with that unless I really have to. They can also be got from RS-Online but in packs of 20 and I only need 4 and some spares.
Does anyone know where I can buy these individually in the UK?
Mook
3 REPLIES 3
pwatson
Fixes: 287
Re: UK supplier of RJ50 plugs.
Farnell will supply them singly http://uk.farnell.com/te-connectivity-amp/5-557963-3/modular-connector/dp/1654823 . I think they've got a minimum order value of £20 though , unless you have a trade account.
Hi.
Thanks for that pwatson, just bought two listed on the UK URL at the bottom of your post.
Farnell, I never even thought of them and I've got a CPC account!
Mook
