Turning router off for a long period
Kat
Hi all. It says in the manual that the router should not be turned off. If I need to have my electrics turned off for a long time - weeks maybe - will this cause a problem with the router when reconnecting? Will it reconnect automatically? Many thanks if you can clarify this for me.
3 REPLIES 3
Fixes: 395
Re: Turning router off for a long period
Hi and welcome,
It won't cause any problem at all, it will reconnect automatically. It's just not recommended to turn the router on & off repeatedly.
MatthewWheeler
Fixes: 479
As MisterW has advised you should be fine.
 Matthew Wheeler
Kat
Many thanks, you have put my mind at rest Smiley
