Turn off WiFi on Plusnet Technicolor tg582n router?
SCat
How can I Turn off WiFi on Plusnet Technicolor tg582n router?
6 REPLIES 6
CJT-80
Fixes: 4
Re: Turn off WiFi on Plusnet Technicolor tg582n router?
@SCat
According to this PlusNet support video, go into the Technicolour gateway, go to Home Network, click Wireless, click Configure.
This brings up the Wireless menu, @ 0.44 there appears to be a Interface Enabled tick box, what happens if you untick it?  That may be wireless off.
Kind Regards,
CJT
Fixes: 383
@SCat , @CJT-80 easier way - press the Wi-Fi button on the top of the router.
CJT-80
Fixes: 4
@jab1
now that's simple 😀
Kind Regards,
CJT
Fixes: 383
I always try to find the easy way, @CJT-80  - makes life simpler.😉
SCat
Thanks, I found it. When I looked at this before, I did not realise it was a button, It looks like an indicator lite in a panel of indicator lights.
Fixes: 383
@SCat Yes, it does, which is a bit confusing.
