Turn off Firewall?
martinnoz
Turn off Firewall?
I can not access most web pages unless as is suggested by "troubleshooter" turn off firewall. I do this with Mcafee and problem is solved for the 15mins I have allotted for it to be off. but then what? I am running windows 7, and am not very computer literate.
martin
10 REPLIES 10
Fixes: 1,482
Re: Turn off Firewall?
if you wish to use McAfee have you tried uninstalling and re-installing it in the first instance?
To be honest there are better options out there, both free and paid for.
7up
Fixes: 17
Get rid of McAfee and get something proper.
It's the cheapest, trashiest and worst quality protection you can get. I've had it on numerous machines (it comes prebundled usually to guarantee custom) and it's nothing but hassle on every occassion.
St3
Aspiring Champion
Fixes: 5
I dont understand why people buy into other anti virus programs the one that comes built into win 10 is perfect.
martinnoz
Have found that instead of using Yahoo, I use Google or firefox I have no problems no idea why.
7up
Fixes: 17
So you found that using a different search engine solved your problem and awarded yourself the "this fixed it" prize lol.
Just get rid of McAfee. Like I said to you earlier it is nothing but trouble.
Fixes: 1,482
There was a yahoo browser once upon a time.. I hope the OP wasn't using that!
7up
Fixes: 17
Must admit i did have to think a bit when yahoo was mentioned, then i figured it was being used as a search engine. I never knew they had their own browser, i guess that must have been really early on!
The early yahoo brings back a few memories.. now i'm feeling all nostalgic lol.
martinnoz
Mcafee comes free with "Plus net broadband"
Fixes: 1,482
It comes part of plusnet protect, but in this case the OP wasn't using this I believe.
7up
Fixes: 17
Yes but there are free anti virus programs that are much superior to McAfee which as previously mentioned is bundled on most new machines for a reason - it's quality stinks and its the only way they can drum up business.
Download Avast, thats pretty decent and free.
