Tunein station unavailable
- Tunein station unavailable
06-09-2020 10:29 PM
I can connect to Tunein Offshore Radio Sounds through various other internet connections, but cannot through PN unless I use a VPN.
Is this a networking issue or is the station blocked by PN for some reason?
Steve
Re: Tunein station unavailable
07-09-2020 1:41 PM
The TuneIn app on the Now TV box works without any problems on Plusnet.
07-09-2020 2:17 PM
Thanks.. It's odd because this doesn't for me
https://tunein.com/radio/Offshore-Radio-Sounds-s141022/
07-09-2020 2:50 PM
OK from here on Firefox:
Tracing route to tunein.com [104.17.58.239]
over a maximum of 30 hops:
1 1 ms 9 ms 6 ms 192.168.X.X
2 23 ms 27 ms 42 ms 250.core.plus.net [195.166.130.250]
3 16 ms 13 ms 19 ms 84.93.253.83
4 24 ms 14 ms 14 ms 195.99.125.136
5 17 ms 14 ms 19 ms peer7-et-0-0-4.telehouse.ukcore.bt.net [109.159.252.156]
6 * 47 ms 18 ms 109.159.253.95
7 14 ms 14 ms 14 ms 104.17.58.239
Trace complete.
ADSL2+ Billion 8800NL
07-09-2020 3:33 PM
So are you saying that Offshore Radio Sounds plays for you, or that you can ping and trace to Tunein generally?
I can connect and use Tunein with other stations OK
07-09-2020 4:10 PM
Ah, OK, understood more fully now.
Yes, ORS is fine, and yes, the trace was to the site in general.
07-09-2020 4:14 PM
07-09-2020 4:35 PM
Thanks.. yes I've tried other browsers and turning off ad blocker to no avail. ORS is also blocked on my Android mobile Tunein app when connected to my wifi. Suggests maybe a router issue or a PN block as the VPN works fine.
25-09-2020 7:29 PM - edited 25-09-2020 7:37 PM
Works for me on my Plusnet connection
Tunein are also blocking a lot of radio stations due to UK court action, but I don't think it is your problem
27-09-2020 5:29 PM
I've discovered that it's not only TuneIn that doesnt work with ORS... If I use Streema or Internet radio I get the same problem of a block.
It would seem that their server is for some reason blocking my fixed IP. Change it and all is well.
Thanks for everyone's comments
