Trojan threat
- Re: Trojan threat
Trojan threat
25-09-2013 10:46 PM
I have Avast ! installed, and every ten minutes I get an alert to say that Avast! has blocked an attempt to instal a trojan. There are two processes reported regularly :
c:windows32/services exe - Win 32 Malware gen
and
Win32. sirefef.btt trojan
I have done the obvious things, namely :
1. Executed a virus scan - no results, except the above two items in the Virus Chest
2. Re-booted the router to change the ip address.
3. Re-booted the computer for the same reason.
Is there anything else I can do because it is driving me bonkers !
Thanks.
Re: Trojan threat
25-09-2013 10:55 PM
Re: Trojan threat
26-09-2013 12:37 AM
MalwareBytes doesn't always get rid of them though if they're installed with a rootkit so you may need TDSSKiller or RogueKiller to finish it off and remove the rootkit.
After that download ComboFix which will reinstall original versions of the affected operating system files (eg services.exe, explorer.exe etc) and will reset your systems security permissions such as firewall and UAC. Note you'll get all the annoying popups asking for permission again etc.
Google will find you the download links.
Of course sometimes you can simply boot into safe mode, remove some registry keys and rename the actual files / folders but that tactic doesn't always work and you really have to know what you're looking for.
Re: Trojan threat
26-09-2013 9:31 AM
its the best one to use http://www.malwarebytes.org/products/malwarebytes_free/
Re: Trojan threat
26-09-2013 8:48 PM
Re: Trojan threat
10-10-2013 12:12 AM
Re: Trojan threat
10-10-2013 12:56 AM
1 subdomain for £6.50 per month? - Seriously?
Yikes.
Re: Trojan threat
10-10-2013 9:03 AM
It's not perfect, but it can work and is free.
http://www.microsoft.com/en-gb/security/pc-security/malware-removal.aspx
Be sure to scan every memory stick, flash card, SIM and external HDD that has touched the machine too, as these can be vectors for the Malware via the disasterously implemented Windows Autorun file.
Re: Trojan threat
10-10-2013 1:13 PM
Quote from: Sprite 365webhost247.co.uk you know that dragging up old threads just to find something to post about for publicity is pretty lame don't you?
Yikes.
His signature appears to me to be in contravention of the forums rules:
[quote=http://community.plus.net/forum/index.php/topic,218.0.html#post_avatar]Avatars and Signatures
The forum moderators reserve the right to ask any member to change their Avatar and/or Signature, should they feel that it is inappropriate, or does not comply with the following guidelines;
Avatar size should be limited to 80 x 80 pixels and a maximum file size of 40kB
Use of the Plusnet (Force9, Free-On-Line, Metronet) Logo as an Avatar is reserved for staff.
Signatures should use no more space than 5 lines of standard sized text would, this includes any blank lines and images you choose to use. Image based signatures should be limited to 100 x 560 pixels and a maximum total file size of 40kB.
The use of advertising links which confer a benefit to the poster are not acceptable.
Re: Trojan threat
10-10-2013 8:19 PM
jim:quote
Re: Trojan threat
12-10-2013 8:00 PM
as for my tech support i'm a network manager 5000 + systems in the daytime and have been for 15 + years
"what do you do?"
In my experience you get what you pay for how many subdomain would like?
and i will keep the price!
dont take it personal i know i wont lol
Re: Trojan threat
16-10-2013 1:54 PM
You're running a very clever idea. You know PN is picked up by google every 5-10 minutes and you've decided to get your company domain in on the action.
Smart yes. Immoral definitely.
Re: Trojan threat
20-10-2013 10:26 PM
just 45 years
The reason it was a one liner is simply because the original poster had not replied or identified that the problem
was still ongoing. I was not go to waste time like i am now.
Why dont you go to ninite.com and install and update all the securiy tools
im sure one of them will find or identify the problem for you then post the results
