Transferring slides to a computer
- Transferring slides to a computer
30-12-2012 4:53 PM
I think someone recently asked the question about transferring slides to a computer, normally I used a Epson Perfection 2480 for the job but unfortunately despite upgrading the software no way would it scan the slides so I had to resort to purchasing a stand alone slide scanner, for what few slides I had the idea was to purchase the cheapest device available which I did,
http://www.maplin.co.uk/5mp-compact-film-and-slide-scanner-647101
Works fine and am well pleased with it, used with Windows 7 (64bit) ? may also work on linux but not tried that yet.
Final Point this offer finishes on 31st December so be quick !!
We are born into history and history is born into us.
5 REPLIES 5
Re: Transferring slides to a computer
30-12-2012 5:05 PM
I've used one of these for some time and scanned loads of slides and negatives to PC.
30-12-2012 6:06 PM
Thanks for the link.
I don't have many slides/negatives to scan so haven't wanted to pay out a lot of scudos. This seems just the ticket. I have reserved to collect tomorrow.
Forum Moderator and Customer
31-12-2012 12:32 PM
Looks like Maplin have extended the offer to 22nd January.
04-01-2013 6:30 PM
Just don't use this one http://www.theregister.co.uk/2013/01/04/slide_scanner_malware/
04-01-2013 7:18 PM
You had me worried there for a minute !
