Transfering Photos from my Android Samsung Galaxy S2
- Transfering Photos from my Android Samsung Galaxy ...
16-07-2013 9:55 AM
Re: Transfering Photos from my Android Samsung Galaxy S2
16-07-2013 10:11 AM
http://www.google.com/intl/en_GB/drive/start/download.html
16-07-2013 10:33 AM
16-07-2013 2:26 PM
thanks for advice
16-07-2013 2:51 PM
I've just done it, albeit from my Nexus 7 to my office Windows box, can't see it being vastly different to your Mac.
Quote but appears to be difficult to use to transfer pics
Just run Airdroid on the phone, make the connection from a browser on the Mac, Open the 'Files' folder by clicking it, drill down to where your photos are ( mine are in the DCIM directory ) , select the photo(s) you wish to transfer and then click Download. If you select more than 1 photo it will download a zip containing all the selected photos.
NB the Airdroid desktop also has a Photos folder which should be the same as above.
edit: I've tried from my Nexus 7 to my Linux system at home using Firefox and that works just the same so I would assume the browser on OS X ( Safari ? ) should work.
16-07-2013 3:57 PM
Can't you just plug in the S2 and see it as a "drive"?
16-07-2013 5:32 PM
Nope. Android Jelly Bean doesn't implement USB Mass storage mode, it uses Media Transfer Protocol(MTP) mode. I'm not a Mac user but I believe MTP isn't supported natively by OS X yet. There are options to install software on the Mac to support it ( I think ) but from my experience I thought it would be easier for tgr to install Airdroid on the phone and keep the Mac standard.
Quote Can't you just plug in the S2 and see it as a "drive"?
16-07-2013 5:50 PM
16-07-2013 6:50 PM
16-07-2013 11:04 PM
Quote from: tgr I must have just pressed the right buttons
Often the best way
I'd also like to thank MisterW, I didn't know about Airdroid but I do now.
31-07-2013 8:33 PM
11-04-2017 11:26 AM - edited 12-04-2017 8:34 AM
I also have Samsung phone and I use Android Mobile Manager tool to transfer photos, it provides both Windows and Mac versions which support to transfer dtaa from Android to Windows or Mac, easy to use. How to transfer Photos/video from Android to PC.
Another choice is Android File Manager, both of them can be used to transfer data from Android to PC and transfer data from Android to Android.
on
22-05-2017
9:47 AM
- last edited on
22-05-2017
2:53 PM
by
Mav
As I know, transferring photos from your Android to Samsung Galaxy S2 is not difficult. We can use mobile phone transfer tool be our help. With its help, we can directly transfer photos between them after we connect both of them to computer via usb cables.
Moderator's note by Mike (Mav): Post released from Spam Filter
