Transfer Hosting to plusnet
sohqam
i have currently registered my domain with freeparking.com but i want to trasfer its hosting to plusnet so through which procedure do i have to go . Does anybody know ?
3 REPLIES 3
mal0z
Re: Transfer Hosting to plusnet
acr
Assuming that you have an account with Plusnet that allows domain hosting then you need to follow the instructions here:-
http://www.plus.net/support/domains_and_dns/dns/dns_hosting.shtml
Make sure that your ticket makes it clear that you require hosting only, with the management being kept with freeparking.com.
The hosting allowances for each account can be found here:
http://www.plus.net/support/domains_and_dns/hosting/hosting_allowances.shtml
The webspace / bandwidth allowance can be found here:
http://www.plus.net/support/webspace/tips_and_info/webspace_faq.shtml#9
sohqam
Thanks for your reply. it did help me alot. hopefully i will transfer my hosting soon.  what does it mean "Wait for the change to become visible on your domain records"  would it take place on plus net account where i have currently my broadband account and have got facility for hosting too.
Regards
