Tplink TD-W9980 & 5Ghz wifi
- Re: Tplink TD-W9980 & 5Ghz wifi
27-02-2018 4:58 PM
Recently I have been using some stuff connected to the 5Ghz wifi, Internet etc works find but when it is on 5Ghz I can't connect/ping it from the local network.
There is NO firewall rule to disable access to the local network, and if I switch the unit to 2.4 it connects fine.
Anybody come across this before?
2 REPLIES 2
08-03-2018 11:38 AM
I have the same router, 5Ghz seems fine. Have you applied an Open-WRT hack, reason I ask is that the 5Ghz doesn't work on WRT.
08-03-2018 11:41 AM
No I haven't. Strangely it has started working.
Only change was the phone was re-booted. And no it isn't a M$ phone 😉
