Touchpad issues
- Touchpad issues
Touchpad issues
22-11-2011 10:56 PM
Re: Touchpad issues
22-11-2011 11:04 PM
Re: Touchpad issues
22-11-2011 11:12 PM
Re: Touchpad issues
23-11-2011 1:52 AM
Get a mouse.
Re: Touchpad issues
23-11-2011 7:21 AM
Quote from: penfold There is an unknown device reported, but whatever I do, this stays as it is.
Does it go away if you disconnect the cable to the touchpad then run the computer?
Re: Touchpad issues
23-11-2011 9:30 AM
Quote from: A Touchpads are impossible to use anyway.
Get a mouse.
I bought a micro mouse at the same time as my Viao. But there is isn't always a surface available to use when you're on the move and the space beside the touchpad isn't always enough
Forum Moderator and Customer
Re: Touchpad issues
23-11-2011 9:36 AM
Re: Touchpad issues
23-11-2011 10:42 AM
Quote from: Mav
Get a mouse.
I have a spare laptop that I keep in the car, and use my right knee to use the mouse on, with the laptop almost vertical resting back on the steering wheel....
(note to pedants, and road safety officers... I do not use the laptop whilst the vehicle is in motion. )
Re: Touchpad issues
23-11-2011 10:51 AM
Quote from: shutter I have a spare laptop that I keep in the car, and use my right knee to use the mouse on, with the laptop almost vertical resting back on the steering wheel....
Not sure if that will work with my bony knees
Re: Touchpad issues
23-11-2011 10:58 AM
I've posted about this before, you need this - Wheelmate Laptop Steering Wheel Desk
Re: Touchpad issues
23-11-2011 11:12 AM
Re: Touchpad issues
23-11-2011 8:18 PM
in bits for a good couple of days, until new touchpad assembly arrived. Looking at the new one there was a plastic tab on it, which i assumed was to aid removal. No!!!, after examining the old one, seemd the contacts are at the top. What the tab is for is anyones guess. Anyhow its fixed. Note to self... Next time take photos
