Torrents and file sharing
- Torrents and file sharing
19-06-2014 7:31 AM
Re: Torrents and file sharing
19-06-2014 7:38 AM
If it is a very popular torrent, maybe try limiting your incoming connections and upload bandwidth.
19-06-2014 7:41 AM
EDIT: ok, I found something that is downloading, but something isn't right. And what about the HTTP download causing the router to need rebooting?
19-06-2014 7:46 AM
19-06-2014 7:49 AM
19-06-2014 7:53 AM
19-06-2014 7:55 AM
19-06-2014 8:03 AM
I can download normally everywhere else, like Macupdate, etc, except anything torrent. Can this really have something to do with the physical router? I'm no expert, far from it, but it doesn't seem likely to me.
19-06-2014 8:55 AM
All's well now. Don;t know what happened but the restart did the trick. Sometimes I forget the simplest is often the best.
19-06-2014 9:11 AM
Glad you got it sorted
19-06-2014 9:22 AM
It's probably down to the number of connections being made and then not being closed down properly. If you do a netstat from the command line if it happens again you'll probably see 100s or maybe even thousands of open sessions that haven't been closed down properly. The torrent client is probably opening them and not closing them so the router keeps the mapping open, restarting the router clears the route but only temporarily.
Plusnet Technology
