Torrent speeds? Whats the best time?
LuthersBoots
HI there. I am experiencing really slow torrent download speeds?
Whats the best time to download torrents and settings to use for Vuze?
Fixes: 135
Re: Torrent speeds? Whats the best time?
Hi LuthersBoots. You could have a look here and select your product.
Customer and Forum Moderator.
Fixes: 247
Unless you are on pro between midnight and 8am
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
